OK. I'm about to buy an Olevia 23" TV (I know it's small, but it's all I can afford
) The set says HD-Ready on Olevia's website although it's listed as HDTV on the sites it's sold at. From what I've read about HD-Ready, it seems that as long as I'm getting my HD channels from DirecTV (which will be the case) then HD-Ready is all I need. However, I'm wondering if I decide to buy an HD-DVD player down the road, will I also need to purchase a separate piece of equipment to use this with my TV? Any better explanations of what this HD-Ready means would help. Thanks.
Also, I've been told that when hooking up my PC to the tv through VGA, I will need a thicker gauge cable than what is normally used. Is this true? If so, is the Belkin High Integrity Monitor Replacement cable going to do the trick (like the one on Staples website) Or do I need to get something else? If so what?
Thanks for any help anyone can give.
-Ryan
) The set says HD-Ready on Olevia's website although it's listed as HDTV on the sites it's sold at. From what I've read about HD-Ready, it seems that as long as I'm getting my HD channels from DirecTV (which will be the case) then HD-Ready is all I need. However, I'm wondering if I decide to buy an HD-DVD player down the road, will I also need to purchase a separate piece of equipment to use this with my TV? Any better explanations of what this HD-Ready means would help. Thanks.Also, I've been told that when hooking up my PC to the tv through VGA, I will need a thicker gauge cable than what is normally used. Is this true? If so, is the Belkin High Integrity Monitor Replacement cable going to do the trick (like the one on Staples website) Or do I need to get something else? If so what?
-Ryan
