Re: I need help with new monitor
Also, try updating the video driver to the latest one on the videocard maker's website.
"Jee-sus, it's like Iwo Jima out there" - Roger Sterling on "Mad Men"
Patcave | 2006 Films | 2007 Films | Dragon*Con 2009 | Heroes Con 2009
I have a similair question as well. I just got new Dell XPS 420 with a dedicated video card, ATI 2600 with 256 mb. and a new LG 22" widescreen monitor. It is connected via a vga from the monitor to a DVI adapter to the computer. The monitor has a max resolution of 1680x1050 but when I set it at this the wallpaper doesn't fill the screen and web pages look too small. The best resolution seems to be 1024x768. Is this normal?
I know enough to know I don't know enough!
Thanks for the info, I went home and found a wallpaper that was the proper rez without having to stretch but I will try it when I download some vacation pics which are 4x3.
I found a workaround on the resolution issue, I kept the rez at 1680x1050 and there is a zoom feature on the bottom right hand side that I can select 100, 125, or 150%. Most sites look fine at 125 but some sites that are not optimized for widescreen can go 150.
Oh, BTW, where have you been hiding Bobby?
Quote:
Originally Posted by bobbyg2
I just haven't had much time to get onto the computer between school and work. I've been reading a little bit every once in a while, but never really had much of a chance to post. Glad to hear you got your problem fixed.
Good to know you are using your time wisely, not that this isn't. I have not been spending as much time on because we got our internet turned off at work. This forum is like a drug, i would come home and try to catch up with everything but I finally realized I couldn't read every post!
Regarding my problem, when you play older games, the monitor stays in the lower resolution and you must manually reset it, according to a co-worker. Thats what started this whole issue but at least I got to find out more about my new system, welcome back, don't be a stranger.
