I've had a Sony SD-DVD player for years: DVP-NS415. It works perfectly and has a better interlaced picture and a WAY faster loading time than any of Sony's subsequent models. (I know, I've checked)
I decided to open it yesterday to vacuum the dust out and hopefully give the laser lens a clean. Unfortunately, I was unable to get access to the lens, as it was housed in a unit I couldn't remove.
Anyway...
Just as I was about to put the lid back on, the screwdriver literally brushed past something near the power switch inside the player. Without any noise or warning, the player switched to standby and now doesn't switch on. I foolishly had the unit on, to open and close the tray. (trying to get access to the lens)
What can I do now? If I take it to be repaired, I'm sure I'll be robbed blind.
Any ideas?
of IFCON (IC404) on the IF-
