Home Theater Forum  ›  Forums  ›  Home Theater Hardware  ›  Speakers and Subwoofers  ›  Best Subwoofer
Best Subwoofer
#1
Rating: 0
I was wondering which subwoofer would be better. Personal experiences, online reviews, etc. are all welcome. My room is 15ft wide by 12ft long by 8ft high. (However, half of one of the walls is open to the hallway). Thanks.
Outlaw Audio LFM-2 $299 8" woofer 150w
HSU STF-1 $299 8" woofer 150w
Seeing mazersteven's comment, I was wondering if anyone has any experience on whether the HSU STF-2 10" 200w subwoofer ($349) is worth another $50 (compared to the STF-1) for my room size? Does it produce significantly better bass (lower, louder, cleaner?)? Also, would the SVS PB10-NSD 10" 300w subwoofer ($429) be worth the extra $80 over the STF-2? Another sub in this price range that looks interesting is the Outlaw Audio LFM-1 Compact 10" 225w ($399) Thanks.
Export to Wiki
#2
Rating: 0
Re: Best Subwoofer
If you could step-up just a little more I think you would get a lot better performance for your size room.
SVS PB10-NSD
SVSound - Box Subwoofers
HSU STF-2
HSU STF-2 Subwoofer
Mazer
http://community.webshots.com/user/maze069
Export to Wiki
#3
Rating: 0
Re: Best Subwoofer
I would get a SVS unit. I bought a SVS unit way back in early 2001 and the thing still cranks out the bass.
Export to Wiki
#4
Rating: 0
Re: Best Subwoofer
I WOULD SAY ANYTHING UNDER 300 WATTS IS A WASTE OF MONEY. BECAUSE IT'S ONLY 150 WATTS-SUB AMPS ARE ALL RATED AT 4 OHMS, BUT YOU DOULD BUY SOMETHING LESS EXPENSIVE NOW AND LATER UPGRADE THE PLATE AMP, THE AMPS ARE CHEAP, ONE OF THE BEST PLATE AMPS ARE KEIGA AND YOU CAN PICK ONE UP ON E-BAY FOR AROUND $299.00, THAT'LL PUMP OUT 600 WATTS. I WOULD STAY AWAY FROM THE BASH DESIGN AMPS, NOT THAT GREAT
Export to Wiki
#5
Rating: 0
Re: Best Subwoofer
I WOULD SAY ANY SUB UNDER 300 WATTS IS A WASTE OF MONEY, BECAUSE ALL YOU'LL GET IS NOISE AND YOU'LL KNOW IT'S THERE. SUBS SHOULD BE INTERGRATED AND SHOULD NOT BE NOTICED AT ALL. ALL YOU SHOULD HEAR IS PURE SOUND, NOT HEEE DO YOU HEAR THAT SUB. ONCE YOUR SPEAKERS STAND OUT YOU DON'T HAVE A GOOD SYSTEM....
Export to Wiki
#6
Rating: 0
Re: Best Subwoofer
That must be the biggest load of drivel I've ever read (and I've read a lot !). Using caps does not automatically lend credence to your statements, it just serves to irritate the hell out of people.
Amplifier power as an isolated metric is one of the worst indications of subwoofer performance there are. The enclosure size dictates how much power a given driver will require.
A subwoofer with a 200 watt amplifier in a large enclosure will lay waste to a tiny cube with a 500 watt amplifier. Better deep bass extension, less power compression. You also make the claim that Bash amplifiers are not great ? Based on what ? A feeling ?
--Regards,
Export to Wiki
#7
Rating: 0
Re: Best Subwoofer
Don't feed the troll now. Look at his limited post history. It's just some kid on the internet withought parental supervision.
Export to Wiki
#8
Rating: 0
Re: Best Subwoofer
CSX-12 seems to be the better of the older model Cadence Xsub 12. For the $300.00 mark w/ shipping. I say go Cadence!
Mike AkA-Frontier
My dvd collection and still more to add. **UpDated**
http://www.dvdaficionado.com/dvds.html?cat=1&sub=MikeySan&id=mikeysan
Export to Wiki
#9
Rating: 0
Re: Best Subwoofer
I've been doing a lot of research on subs and speakers and SVS subs get the most nods = Best bang for the buck!
hyghwayman
Halo 3 Beta Tester
COD 4 Beta Tester
Export to Wiki
#10
Rating: 0
Re: Best Subwoofer
The MFW-15 represents what is arguably the best bang for your buck subwoofer right now. It stomped all of the Velodyne DD-18, equaled a JL Fathom 13 in performance and is $599. Now if you can find something that can top that for the same price then we might get somewhere.
Ta ta.
--Regards,
Export to Wiki
