Home Theater Forum  ›  Forums  ›  Home Theater  ›  Basics  ›  need help on chooseing a new surround sound
#1
Rating: 0
I plan on remodeling my basement into an entertainment room. I know which tv to get but what surround sound should i get. I want an awesome receiver but what brands are better than others? i want one with very little sound distortion. I absolutly love bass so i would like high quality subwoofer. One that can go loud and not worry about blowing it out. Oh and the reciever needs to support wireless speakers and be 7.1. I want it to go so loud that the neighbors down the road will complain. I know i am looking at alot of money here but it will be worth it. Also has anyone heard about JBL? How much are they? I know this is alot here but i can use all the help i can possible get.
Export to Wiki
#2
Rating: 0
Re: need help on chooseing a new surround sound
You'll need to tell us what the dimensions of the room are, and what your budget is for the receiver and speakers. The size of the room will determine what kind of speakers you will need and what size of sub to produce enough bass to make the neighbours down the street complain.
For starters though, you can take a look at SVS subs here. They make very powerful subs that produce clean, deep bass that should produce the effects you seek.
Export to Wiki
#3
Rating: 0
Welcome to the forum bluedev - there's aLOT of info here regarding audio (if you haven't noticed) so take a look around and I'm sure you'll find info on nearly any audio device you can think of. And yes I've heard of JBL - they make very fine speakers, have been around for many-many years and are solidly built.
Home Theater Systems Component Advice, Info, Tips & General BS
Export to Wiki
