Re: Taskbar Help
It is likely you have 'stacked' your taskbar. Take a look at the faint vertical lines at the left and right - usually next to your start button and system tray. Click on one, hold it down, and try dragging it to the line where your start button is. Windows is really quirky about this, so you may have to try doing it more than once.
Also - make sure your taskbar is not locked. Once you have it the way you want it you can lock it again to avoid this happening again.
Martin Luther observed that the human race is like a drunkard who falls off his horse on the left and makes up for it by falling off the next time on the right.
