Home Theater Forum  ›  Forums  ›  Other Diversions  ›  Computers and HTPC  ›  Need some pc help ASAP
#1
Rating: 0
Hey..I build pc's on the side and I seem to be having a problem. Seems anymore when I build them they have a hard time turning off.
I go to START, Turn off Computer and choose to turn it off....Then it sometimes reboots or turns off halfway "but not really"..What the heck is the problem?
About me..Im a gamer, I workout, I love music and movies. I reallly like BASS IN MY FACE!!!....Im crazy, fun, silly , and make people pee their pants..lol...I think I just did!
Export to Wiki
#2
Rating: 0
Re: Need some pc help ASAP
BIOS and/or OS drivers for the hardware (motherboard, disk controllers, etc.) Generally speaking, you try and get the latest version of everything, then hope for the best. It's possible that the latest versions simply do not work reliably (yet). That's one risk of building your own. You can try different combinations of stuff. Older hardware and OSes (like XP instead of Vista) are probably more likely to work, since they've had a chance to iron out these problems.
Export to Wiki
#3
Rating: 0
All I use is XPpro. You have any idea what else it might be..I hate selling a pc that wont turn off..lol..
Export to Wiki
#4
Rating: 0
Are you using the same motherboard in every build? If so, what is the brand and model number? It may simply be a driver/BIOS issue with a particular motherboard as Ken mentioned. The fix might be as simple as a BIOS or driver update, or you may have to switch to another motherboard entirely.
-Keith
Export to Wiki
#5
Rating: 0
Different motherboards. I wil look and see if there are any updates on the bios, but I dont understand how that would effect shutting down...Can you clarify this for me??Thanks much
Export to Wiki
#6
Rating: 0
I had a similar problem. I tracked it down to the video card. I forget the exacts - something to do with a non-agp video card ... I'll try to remember..
edit - still working on it. The card I was using had an onboard video card. I installed a PCI video card. There was a file which didn't install when I put in the driver software. When I reinstalled it everything went fine. It hs something to do with it being PCI and not AGP. I wish I could remember more. I hope this is helpful...
Martin Luther observed that the human race is like a drunkard who falls off his horse on the left and makes up for it by falling off the next time on the right.
Export to Wiki
