Re: need help getting 5.1!
If your receiver doesn't have HDMI, then you need to run a coaxial digital cable to the receiver. This WILL give you 5.1 for sure. Your set MAY pass 5.1 through via optical from the HDMI in, but that is hard to say as I have seen people say that some TVs won't pass 5.1 this way, so you might have to check for your particular set.
Configure the player for bitstream and make sure dts is turned on also in your digital audio setup in the player and you should be good to go.
"The trouble with the world is not that people know too little, but that they know so many things that ain't so." - Mark Twain
HT: Marantz SR-8300, MA500 mono, Audiosource Amp300, 5X GR Research A/V-2s, Adire Audio Tempest sub, Oppo BDP-83, RC2000MkII, Panamax 5100, Panamax Max2 sub, PS3 60G (250G)...
The optical outputs on tvs, are usually just for getting 5.1 from HD programs received on the built-in digital receiver. It's not for a pass through, like you were asking about.
Do what John said, and you should be ok, even with the cheap cable you have. Most dvd players don't come with DD or DTS turned on. You have to do that, in the setup menus.
Good luck!
Samsung HL61A750 (LED DLP) Onkyo TX-SR805
Denon DVD-2200 Polk Audio LSi9
Polk Audio LSiC Sony SS-MB100H
JBL PSW1200 (Sub)
