Home Theater Forum  ›  Forums  ›  Home Theater  ›  Basics  ›  Analog DTS Sub Problem
#1
Rating: 0
I've been having a problem using my DVD player's onboard DTS decoder to feed analog 5.1 to my receiver, and wondered if anyone here might have some insight. The problem is simply that using this set-up, no signal makes it to the sub when playing a DTS audio stream. The problem isn't related to bad connections because the sub works fine with DVD-Audio discs using the onboard DVD-Audio decoder. Until now I've just been using the digital feed and my receiver's DTS decoder, but I'd like to try analog, which I suspect will sound more crisp on my system if I could get the sub working. Of course I'm at work and don't have my model info, but the DVD player is a Panasonic. Thanks for any thoughts...
Export to Wiki
#2
Rating: 0
Re: Analog DTS Sub Problem
You'll have to crank the sub's level up quite a bit. DD/dts have a +10dB offset added to the .1 channel while SACD and DVD-A do not. Some players and receivers have a feature to compensate for this, so I'd look for that first on each, but if not you'll have to manually adjust the trim levels.
This should not be the case for dts, though there is also a separate setting for that on most dts capable players.
99% of receivers will have better bass management than the player, so for DD/dts tracks, I'd use digital.
You cannot get DVD-A tracks via digital unless you have both a player and receiver that are capable of this, which many are not.
"The trouble with the world is not that people know too little, but that they know so many things that ain't so." - Mark Twain
HT: Marantz SR-8300, MA500 mono, Audiosource Amp300, 5X GR Research A/V-2s, Adire Audio Tempest sub, Oppo BDP-83, RC2000MkII, Panamax 5100, Panamax Max2 sub, PS3 60G (250G)...
Export to Wiki
#3
Rating: 0
Thanks for the thoughts. I'll check the setup on the player again. Unfortunately I already tried cranking the sub. Hopefully I just missed something in the setup that will fix the problem.
Export to Wiki
