MarkO
- Feb 19, 1999
Has anyone tried this?---> http://www.ppg.com/gls_aquapel/main.htm
You can do the Zaino in one day, no problem. Just buy the ZFX instead of the Z1 and you only need to let the polish dry for about 30 minutes before removing it. Makes it much easier.
Thanks, Tim!
From the comments here, guess I'll look further into Zaino.
I belong to another (vehicle-specific) form where it is common for owners to have 20-30 coats of this stuff on......and the pictures are incredible.....it looks like a mirror on black vehicles!
Are the ZFX and Z2 liquids or creams? To mix it, would you just get a third container, pour in both and shake?Z-2 or Z-5 are like a CREAM and ZFX is a thin liquid in a TINY bottle with a drip applicator top.
The ZFX kit comes with 2oz. mixing bottles.
Fill one halfway with Z-2 OR Z-5 and then add 3-4 drops of ZFX.
Mix and apply.
Shawn S
Is the Z6 Gloss Enhancer really necessary?No, not necessary. I find that it really helps repel dust, though. You might consider just using it as the last step instead of between every coat if you're not worried about the glossiest possible finish.
