BrianEK
- May 6, 2003
I have been reading many threads about component video switchers. I have a new HDTV and already ran out of inputs. From what I've read you have to spend at least $100+ to get a good switch that doesn't affect quality. can I just use a good Y-splitter cable? I saw some good looking monster cable 2 female to 1 male connectors and they are only $15 a piece. So 3 packs are a lot cheaper than the component switch. But I want to make sure I won't lose significant quality because the monster cable splitter is technically meant for audio, at least that is what the box says. So I don't know how this might affect a video signal. I would be hooking up my prog. scan dvd player and HD box to the splitter. Tell me if this would be OK solution without affecting quality significantly.
