X-Box problem...What to do?
Discussion in 'Archived Threads 2001-2004' started by Arthur Legardo, Nov 18, 2001.
  1. Arthur Legardo
    Arthur Legardo Second Unit
    Jul 21, 1999
    441
    I've gone through my second X-Box in two days, both units have had the same problem: Halo and Munch's Odyssey only ouput in stereo, not 5.1 [​IMG]
    Should I return everthing and say "To h@ll with Microsoft"? Or should I send it off to Microsoft and have them fix it? Or should I just be satisifed that I can at least approximate 5.1 with DPL2 (with my Denon 3802)?
    Your opinions please...
  2. Jeffrey Noel
    Jeffrey Noel Screenwriter
    Sep 11, 2001
    1,533
    I would NOT settle with anything less than what the X-Box is supposed to do! If you haven't already, I'd call the X-Box help line to see what they say. If they say they don't know what to do, to hell with them!!
    But, if you do decide to say "Screw the X-Box" and get a Gamecube, just remember that it does not offer 5.1. But let me tell you, it is amazing!
    Best of luck on whatever you decide!!
    GAME ON!!
    God bless!
    jeffrey noel
    My DVD Collection
  3. Morgan Jolley
    Morgan Jolley Lead Actor
    Oct 16, 2000
    8,572
    92
    GCN doesn't offer DD5.1, but it can do DTS I think. I know its not as good, but at least its something.
  4. James St
    James St Supporting Actor
    May 8, 1999
    959
    Arthur, I would try to get it fixed or return it for another.Also Gamecube can't do DTS either unless you're talking about Neo 6. A digital output is required for any true 5.1.
  5. Brian Harnish
    Brian Harnish Screenwriter
    Dec 15, 2000
    1,216
    DTS is not as good as Dolby Digital?!?!
    - Brian
    My DVD Collection
    Want Sliders on DVD? Then please SIGN the petition!
    [Edited last by Brian Harnish on November 18, 2001 at 03:39 PM]
  6. ChrisV
    ChrisV Second Unit
    Mar 25, 2001
    484
    How can it do DTS without a digital out?
  7. Stefan A
    Stefan A Second Unit
    May 27, 2001
    397
    Arthur
    Maybe I don't need to say this, but did you use the correct cable and plug it in correctly? Was you equipment on all the correct settings - Xbox and your receiver?
    The 1st xbox I bought would not produce any sound in games. I knew I set it up correctly. The 2nd one worked fine. I guess the odds are that a 2nd unit will work - but not necessarily. If one is broken, many could be broken. Perhaps you were just unlucky and got 2 broken ones in a row.
    Anyway, if you have your heart set on the x-box, do what it takes to get a working one. Exchange if possible or get it fixed. I can tell you (as many others have been saying), that the 5.1 is worth it.
    Stefan Antwarg
    My DVD Collection
    The Regal Brass Quintet Not HT related
  8. Gui A
    Gui A Supporting Actor
    Dec 25, 2000
    596
  9. Tony_I
    Tony_I Stunt Coordinator
    Oct 6, 2001
    77
    Exchange your Xbox and get one without a Sound problem. Bound to be a few bad apples in the bunch...
  10. Aaron Copeland
    Aaron Copeland Second Unit
    Nov 3, 2000
    445
    Aaron
    I'm sort of in the same boat. I can get 5.1 to work, but I'm having problems with a popping sound coming from my speakers from time to time and the sounds dropping totally on other ocassions.
    It's not consistent either. I can sometimes play Halo for a couple hours with no problems. Then I will start it up a little while later and the problems surface again. It's terribly annoying.
    I have tried two different AV packs and both produced the same result. Also, the problem does not occur if I switch the sound to stereo instead of surround. So I'm inclined to believe that the problem lies in the XBOX itself.
    The problem I have is that I bought mine online from EBgames so making a return is going to be a hassle. I'm debating if I should go try and buy another at a place like Wal-Mart (and hope it works) and send my current one back to EBgames for a refund...or should I go ahead and wait for MS to call me back when they track down the problem and possibly have to send mine in for repair?
    Aaron
  11. Tony_I
    Oct 6, 2001
    77
    Hmm... I would try picking an extra Xbox up at a local wal-mart , BestBuy...etc, so you can get back to your 5.1 gaming.
    Send your first one Back to EBgames after you hunt one down from a local.
    I remember hearing a "rumor" about the sound chips having manufacturing problems and being the main reason for the shortage of systems.
    Looks like it wasn't quite a rumor after all [​IMG]
    [Edited last by Tony_I on November 18, 2001 at 04:52 PM]
  12. Jeffrey Noel
    Sep 11, 2001
    1,533
    Umm...Morgan, GCN does not do DTS! Maybe you mean Pro Logic II. GCN does not have a digital out! Bummer though!
    God bless!
    jeffrey noel
    My DVD Collection
  13. Matty B
    Matty B Stunt Coordinator
    Aug 27, 2001
    227
  14. AndyVX
    AndyVX Supporting Actor
    Aug 2, 2000
    804
    It's been posted all over the web on various gaming forums that there are problems with the Sound Chip in a few Xbox's. The result is the popping and cracking of audio and dropouts here and there.
    The only thing you can do to remedy this is to get a new Xbox. You can go through as many AV Paks as you want, but you wont fix the problem.
    Microsoft has yet to release any statement about this problem and what they are going to do about it. Hopefully they are at least aware of the problem and are figuring out what to do about it.
    Andrew
    ICQ# - 119869807
  15. Arthur Legardo
    Jul 21, 1999
    441
    Geez, I go away for a couple of hours and look what happens to my thread! [​IMG]
    Thanks to all of those who replied.
    Stefan A, yes, everything was connected properly to my existing HT. I even bought another S-Video (with toslink) connection kit today just to rule out a faulty original S-Video connection kit. The first one I bought was from Mad Catz, it even said "5.1" on the box. The second one was straight from Microsoft.
    I checked the settings on my receiver and X-Box twice and then rechecked them just to make sure and still "no go". I even pulled out my DVD player's connections (working 5.1), didn't change any settings on the receiver and connected the X-Box to it and still nothing.
    Tony_I,
    quote: Exchange your Xbox and get one without a Sound problem. Bound to be a few bad apples in the bunch...[/quote]
    Now the only problem with this is that the consoles aren't that ubundant up here as they are in the US. I had to go to three different Futureshops to get a replacement for my X-Box.
    Well, I've made my decision, it's going back tomorrow, let's hope they give me a full refund.
    [Edited last by Arthur Legardo on November 18, 2001 at 06:03 PM]
  16. Arthur Legardo
    Jul 21, 1999
    441
  17. Aaron Copeland
    Nov 3, 2000
    445
    Aaron
  18. Stefan A
    May 27, 2001
    397
    Arthur
    Believe me... your problems are exactly what I had. My choice was to either return it and find a new one - or, send it to microsoft for repair. X-boxes are sparce around here too, but if you are tenacious enough, you will find one.
    Stefan
  19. CraigR
    CraigR Agent
    Feb 5, 1999
    27
    Well I've had a similar problem. I can get analog sound but nothing through the optical cable. I've tried different HD AV paks, different optical cables and even the monster cable approach and still no digital sound. It does sound pretty good through my system as is...but I'm thinking this thing should work with the digital cable on sound. Oh, and yes I have gone into the settings mode and made the correct settings. I think I'll check with the store and see what they can do.
  20. Arthur Legardo
    Jul 21, 1999
    441
    Well, I just got back from Futureshop (the store where I bought it from) and they took it back without question (or, questions?)! I just told them that I'd rather wait until a "fixed" version becomes available. [​IMG]
