Would SVCD be a suitable format to use to transfer 8mm video to?
Discussion in 'Archived Threads 2001-2004' started by Terence R, Sep 19, 2001.
  1. Terence R
    Terence R Auditioning
    Jan 27, 2001
    2
    I am considering getting a video capture card. I would like to know if there would be any loss of quality if I transfered regular 8mm video tape to SCVD?
  2. Dominik Droscher
    Dominik Droscher Supporting Actor
    Sep 11, 2000
    531
    SVCD is a very nice format. Not as good as DVD quality MPEG2 or DV but it is still a lot better than VCD or VHS.
    I use TMPG Encoder which is a good sharewere solution.
    -Dominik Dröscher ICQ: 25318265
    "Quis custodiet ipsos custodes."
    [Edited last by Dominik Dröscher on September 19, 2001 at 06:49 AM]
  3. Brian-W
    Brian-W Screenwriter
    Feb 8, 1999
    1,149
    2
    8mm isn't much better than VHS, so techically VCD would be comprable, and SVCD a bit of overkill. SVCD doesn't have the pixel resolution of DVD but is certainly higher in resolution than 8mm.
    Choice is yours but if you get a SVCD encoder, chances are it will have a VCD encoder. Compare for yourself which is better. You'll get more video onto a disc using VCD as opposed to SVCD
    -Brian
