Why is my Sony picture B&W?
Discussion in 'Archived Threads 2001-2004' started by Brian Bauer, Jul 29, 2001.
  1. Brian Bauer
    Brian Bauer Auditioning
    Jul 27, 2001
    I'm a real newbie here. I've been all over this and other HT fora looking for some answers, and this crowd seems the most knowlegeable and friendly.
    I just got my first DVD, a Panasonic RP91. I connect it to my Sony KV-27FS16 via component cables. The picture is B & W. Very detailed, rock-steady, but not what I was expecting, ya know?
    Standard (1 plug) video works
    S-Video works better
    Am I missing some setting?
    I had been looking forward to using the vaunted Progressive Scanning. When using component cables, (still in B&W), I push the button for the famous blue light, and the picture dissolves into diagonal noise.
    I've gleaned from various postings that not all TV's support progressive scanning. --even my 8 month old Wega?
    Thanks in advance for your input, and thanks for the answers y'all have provided for so many others.
    Wega KV-27FS16
    Panasonic DVE-RP91
    Aragon 24K preamp
    Aragon 4004 mark II amp
    Vandersteen 2ci speakers
  2. RoyGBiv
    RoyGBiv Stunt Coordinator
    Apr 10, 2000
    If you're getting a B&W picture, one or more of the component cables is bad, or one or more of the terminals for the cables is bad. The component cables separate the colors from the B&W picture. Try new cables, and if that doesn't work, you may have to play around to see whether it's the DVDs cable terminals or the TVs cable terminals that may be bad.
    To see a progressive DVD picture, you have to be using a TV that can show a 480p picture. I don't believe your TV can do so. Currently, all the TVs I have seen that can are called "HDTV ready." I don't believe your TV is HD. You are getting the diagonal noise because your TV can't generate a picture from the progressive signal.
  3. MarshawnM
    MarshawnM Stunt Coordinator
    Jul 5, 2001
    Only the XBR Wega models can show a progressive picture. Your model is not a digital TV, the XBR's are digital.
    I have the 36XBR400, the reason I spent the xtra money was for the digital tuner = progressive scan DVD and HD via Direct TV. I'm not sure if the 27 inch is made in an XBR model....
