chrisden
- Apr 10, 2002
and what amps are you using to run them? Anyone running them with a high end receiver?
Thanks.
Thanks.
Have you run the 100's with just your Pioneer receiver? If so, how did it sound that way?Yes I have and its sounds very good as well, but with the parasound the bass was noticeably better, more headroom, and plenty of power to spare
with the receiver alone I got shutdowns around -10 on the pioneer display from what I understand the 100s dip down to 2 ohms at some points, the parasound doesn't even break a sweat
I listened to a lot of speakers before buying and let me tell ya not to many speakers will perform like these do for the money! but that's just my opinion I would highly recommend a decent 200wpc amp to power them in order to get the full potential of the studio 100s, parasound, rotel, b&k and many more!!!
Bob, Btw I biwire with kimber 4tc x2 to each speaker roughly $375 just for 4 runs of wire to the mains, but thats another issue too!
