I bought a SD4700 last night and while watching Saving Private Ryan on it the player locked up, so I thought maybe the disc was dirty, so I started Moulin Rouge, and it did the exact same thing! I was reading on this and hometheaterspot.com that the SD4700's have a layer change problem....take it for what its worth but I wouldn't get a Toshiba SD4700.
Took it back this afternoon and exchanged it for a Panasonic RP-56, gonna try it out with SPR tonight.
Derick,
If you're looking for discretes, the Tosiba is NOT the way to go. I've only found a discrete on code for the 5700, which is substantially the same as the 4700.
FWIW, I have not had a single layer change problem with the 5700.
Watch Saving Private Ryan, Final Fantasy and I am now on my 2nd viewing of Mulholland Dr. tonight with the RP-56, not a single problem and my fiance noticed how much sharper the Sage/Farjouda(sp) de-interlacer makes the image.
I am pretty sure that Toshiba has no power discrete codes for anything but their latest crop of rear projection TVs. There are workarounds for this, as can be researched on www.remotecentral.com. The RP-91 is very Pronto-friendly. The one thing that I would have liked is the opportunity to switch the sizing discretely...like from Auto to Zoom for non-anamorphic material that is not flagged. I found that you have to entered a mildly nested menu to get to this option.
