Where to buy DVI cable... (1 Viewer)
Donald_S
I'm buying a Bravo DVD player but the only DVI cable I saw on their site was 6 meters, which is way to long for me. I need a 2 meter cable. Suggestions of where to buy pretty cheap. I see cables for $10 and for $150, and I'm not sure what the difference is. Input would really help.
Donald
Donald_S
I should have mentioned that I'm hooking the Bravo up to a Sony GWIII if that's a factor.
Donald
Shane Martin
Donald,
Lots of folks are buying their DVI cables from Here
Please note I have no experience with these guys but I'm planning on going with one of their cables for when I pick up a new TV early next year. They have a tutorial as well on DVI.
Donald_S
Wow, amazing prices Shane. Thanks for the tip. Now I have to admit my stupidity and say I don't know which cable to get. I would guess it's single link male/male digital, but it's only a guess. Can someone set me straight? Thanks a bunch.
Donald
Shane Martin
They should have a picture guide on there so compare the DVI outs of your 2 devices and you should be able to figure it out. If not You might try calling/emailing them.
AlexanderS
I got a 3m DVI-D (which is the type you'll need) from Pacific cable. Shipping was high because it was cross country but the quality is excellent.
blitz
