Doug_Z
- Nov 24, 2002
I don't know if I should go with 1 or 2 subs. Also I don't know if I should stick with the same brand sub as speakers. I am going with the M&K powered 150P's for my front 3. My rears will be driven by a separate 4 channel amp.The rears will be 4 M&K tipoles. I haven't heard anything negative about these speakers, for HT only purposes, and there are so many speakers to choose from that I have finally made that decision.
My problem now is whether to buy 2 MX-150 thx ultra. 20-200hz with dual push pull 12" woofers and 150 watts. OR 1 MX-350 thx ultra.18-200hz with a 350 watt amp and the same push pull design. Specs say both are sealed although the photo looks like they are ported. Or I could buy one or 2 of another brand sub. The 350 is $1800 which seems like a lot for 350 watts. The 150 is about $1100.
My room is 16x16x8 with an open kitchen and 2 other open doorways. One leads into the living room. The other into a hallway.I have wall to wall carpet. I am thinking 2 subs would be better than one but I would lkie some knowlegable input. Also these M&K subs meet the 10 year old THX specs which were -3db at 35hz. I don't know if they exceed them. The new Ultra 2 specs are +3db at 20hz. I don't know what the audible difference would be.The entire system is designed to interact.
Would I lose any integration of the sub with the rest of the system if I used a different company's Sub.
Should I use one or two subs? Either way what specs should I look for? I know I need at least 20-200 HZ. I am hazy on the meaning of push/pull and how important the wattage is as opposed to the quality of the amp.( I think the 150 and 350 with the M&k's are RMS but they don't say. I know Subs work mostly with peak bass only)
Of course M&K say their system is designed to work together with the 150 or 350. I have a feeling you all would argue that any quality sub would integrate just as well. Any helpful suggestions would be appreciated. Thank you. Doug
