Hey all, my friend and I are trying to install a 64MB NVidia Geforce 4 through PCI slot on my old PC. The old Pc was recently upgraded to 256 MB of ram with Windows XP Pro.
The videocard installs nice and easy but when trying to use it we seem to encounter a strange problem. The monitor doesn't seem to work, it turns on but once it reaches Windows it goes black and you can't see anything or use it. We've narrowed it down to the Geforce because once you try taking the geforce out and using the original integrated video everything works fine.
Is there anyway to fix this? do we install any drivers? I can say for a fact that it worked fine on his other pc? any ideas? thanks.
