NeilO
- Aug 30, 2002
I have a Pioneer VSX-D811S receiver. I just got it hooked up. For the DVD player, I'm just using the STANDARD setting which will recognize the DTS or Dolby Digital signal that is coming in. Now, I am wondering what setting might be the most pleasing for just regular TV audio coming in or audio coming from old prerecorded tapes.
It seems that for tapes which are marked Dolby Surround, that I should use the Pro Logic II Movie setting.
For a regular TV stereo signal, I could use the Direct setting which just sends everything to the front left and right. Or I could use Pro Logic (4.1) or Pro Logic II Movie (5.1) surround which may send some of the signal to the surround speakers.
I am presuming that these type of options are on most receivers, so familiarity with the Pioneer might not be needed.
Neil
Neil
