upgrading a home theater system
Discussion in 'Speakers' started by John Roger, May 12, 2004.
  1. John Roger
    John Roger Stunt Coordinator
    May 12, 2004
    119
    I am currently upgrading my home theater system which previously consisted of small sats and a sub.I have a small sony amp(dts).
    Thinking of bookshelfs for the fronts and matching surrounds.
    I have two Bose 201s, will they do for the fronts?
    Looking for sound quality.My sub can deliver decent bass.
    What are the best brands.Plz advice.
  2. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    I would use the 201's for rears and look to something else for fronts and center. What type of sub do you have? If it's the Bose "Bass Module" you may not be able to use it with other speakers. Please let us know a rough budget for your speakers.
    As far as brands go:
    B&W
    Klipsch (reference series)
    Paradigm
    Polk
    Axiom (online)
    Rockets (online)
  3. Mike SJ
    Mike SJ Supporting Actor
    Nov 10, 2003
    718
  4. John Roger
    May 12, 2004
    119
    I am a bit tight on budget.Looking for
  5. Nhan_H
    Nhan_H Second Unit
    Feb 6, 2003
    431
    John, if you want to have quality speakers, you might want to start out slowly. Get the mains first (and like someone suggested, use the Blose in the rear). Then you can add the matching center once you save up more money. The suggested speakers above are all very nice, but I'd like to throw one more into the mix. htd.com's Level 3 towers might fit your current budget.
  6. Cam McFarland
    Cam McFarland Supporting Actor
    Feb 6, 2004
    699
    [​IMG]
  7. Johnny_M
    Johnny_M Second Unit
    Apr 6, 2004
    281
    i agree with nhan.. buy things 1 by 1, it takes longer but youll be happier in the end. it took me a year to complete my setup. i started with a receiver and 2 towers, later i bought the center and surrounds, later got a sub.
    lastly, the tv haha.
    once you start you will always want to upgrade, so you might as well get used to that. i just bought a HDTV widescreen 42" RPTV, and I already want to move that to the bedroom and setup a front projector with a screen.
    Gotta love toys!
    Johnny
