BigJim
- Feb 19, 2007
- Jim
I picked this up at Fry's as it seemed to have the features I want, and the price was OK, but I'm a bit disapointed.
1. The Dealbreaker is that it doesn't seem to be "learning" correctly from my other remotes. It won't do the numbers correctly from my Toshiba TV remote, even though it was able to re-learn some of the other keys. And it won't do the 'List' button on my DirecTivo. The 2nd one is not a big deal, because it's only two button presses to get there by going to the Tivo menu first, and I could probably make it a Macro. The first one is critical because for some reason when selecting inputs and selecting the screen format for the TV, you can't use the up/down arrows to go through the list, you have to enter a number.
2. The interface is somewhat clunky. I don't see a good way to create a macro for "watch DVD" and have that visible from the main menu. I guess I could map it to like Key1, but then we have to memorize that #1 is watch DVD, #2 is watch Tivo, #3 is listed to CD, etc. Maybe I could overwrite the devices I don't use with my Macros? Or, maybe I can add another screen to the Main menu, and add my macros there, but I haven't figured out how to do that yet.
3. You can't change the devices around on the Main menu screens. 3 of my devices are on the first screen, but DVR is on the second, and there's 4 devices on the first screen I don't care about. If I could move DVR to the first screen, that would be great.
4. I've set up my On/Off Macros to power the DVD, TV and Amp, but it seems that the Macro is enabled even when I'm supposed to be in an individual device mode. So if I want to turn off the DVD player, I can't without turning off the whole system.
If I can't past issue #1, I think, I'm gonna return the thing, and order a Harmony.
