George Caronan
- Nov 25, 2003
Hello all. I own a Sony KV36XBR800 4:3 CRT TV. It seems to convert ALL HD signals to 16:9. It poses a problem through the following set-up:
Kenwood DV-5900M - set to progressive scan with 4:3 LB aspect radio
DVDO Iscan HD - the Kenwood is connected to this via component input and is set to 4:3 input and 4:3 output. Format is set to 1920 x 1080i
The DVDO is connected to the Sony through its DVI input. All of my DVDs in the changer are ALL 4:3. The Sony is receiving the upscaled 4:3 format in 1080i and displays it at 16:9 format. Is this normal? Is there anyway to convert it to 4:3? I called the Sony support center and they couldn't answer it. They mentioned the set's 16:9 enhanced feature but that is ONLY for DVDs in widescreen anamorphic. There is nothing in the Sony's manual about manipulating the aspect ratio. If anyone is familiar with this situation, I would like to hear your suggestions/solutions. All my DVDs in the changer are 4:3 [concert DVDs and TV shows]. Thank you in advance.
