I have a Toshiba 36a60 that when I push the power button does not power up, but the red light just blinks. Does anybody have an idea as to what the problem may be? Thanks!
- Unplug the set and wait a few seconds or minutes - Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system.
If it finds that there truly is a problem, then the set is shut down and the LED will continue to flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
