Toshiba DLP bulb question
Discussion in 'Displays' started by Brad_Cox, Jan 15, 2006.
  1. Brad_Cox
    Brad_Cox Agent
    Jan 14, 2006
    31
    I have a couple of questions about the Toshiba DLP sets. My Dad is considering the 72 DLP from Toshiba but I have worried him because I have heard from various forums that the bulbs go out about every 2 years and they cost a couple hundred bucks.Is this true?
    Also a salesmen told him that you only had to remove about 1 or 2 screws and it could easily be changed without calling out a service person. Is this true? If that is the case then I am pretty sure he would move forward with the purchase.
    Thanks.
  2. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,373
    32
    New England
    Gregg Loewen
    Yes and yes.
    the bulb should be changed after light output drops by 30 %
    Regards
    Gregg
  3. Reginald Trent
    Reginald Trent Screenwriter
    Feb 18, 2000
    1,313
    How can you tell if the light output is down by 30%?
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    Gotta put a new lamp in ever so often, they are easy as pie to change. Well unless your lamp explodes which also happen, still user service-able though.
    So far I have not found one owner that has found this to be an issue though. If he or you think it will be, go with a more maint free display.
  5. Brad_Cox
    Brad_Cox Agent
    Jan 14, 2006
    31
    Thank you all for the information. My Dad's main concern was having to get a service person every time this happened. As long as it is something you can do yourself it isnt much of an issue.
    Thanks again.
  6. John S
    John S Producer
    Nov 4, 2003
    5,460
    Easier than pie to change a projector lamp. [​IMG]
