Scott_W
- Feb 12, 2000
I just picked up a 20" Toshiba TV, the 20AF42. So far, I'm not impressed. I mainly bought the TV for playing videogames with a PS2, and some DVD watching while in my office. I've noticed that when using the component (Colorstream) inputs, the resulting image/video is slightly pushed to the left. In quite a few games, this means I may be missing a small portion of the display. Its also extremely annoying. Some games let you adjust the display, others don't. I have yet to try a DVD player or another console (XBox), but I'm guessing they'll all have similar problems.
Is there anyway to adjust the image? No menu seems to work. I'm guessing that if the input device can't fix it, I'm out of luck.
Another fault of the display, the right border seems to have wave effect at times, causing the image to distort.
This is the first time I decided to save a bit of money and buy a non-Sony. Go figure. I've never had a problem with Sony tvs, they just work.
Anyone have better luck with the 20" Sony TVs with component inputs (KV-20FS100)?
Any help would be great, even if its telling me to return the tv, as its not an adjustable problem... Thanks!
