KenWojo
- Jun 3, 2004
Argh...I don't even know where to begin!
Having only been into home theater for six months (we bought our first home seven months ago I chose to wait until we weren't renting) I don't know if my problems are ignorance or crap hardware. Maybe you can tell me which, if not both.
Here's my problem. I just upgraded my digital cable to HDTV with a DVR. Prior to that I ran my digital cable through coax to the standard ANT in on my TV. This freed up my component video inputs for my DVD player and XBox. Now, with the HD/DVR set top box I need to connect that to one of my component inputs, of which I have only two,
and therein lies the rub. I can't figure out a way to hook everything up, which leaves me with my XBox disconnected and I'll have to go through the painstaking ordeal of pulling out my TV and switching the cables between the DVD player and the XBox. The only alternative
(and, now that I think of it, the *better* alternative) is to hook up the XBox and play DVD's on that.
I've tried hooking everything through the receiver, but for some reason I'd get no video. I also tried hooking the DVD player directly to one of the numerous S-Video ports on the TV (admittedly not as good as component, but better than switching cables around) but none of that worked. For some reason I don't get a picture when I hook the DVD up to S-Video on the monitor...a problem I can't understand in the slightest, and probably a bone-headed mistake.
In addition to the XBox with the HD Pack I have what I thought was a good receiver (Kenwood VR-707) that I purchased as a package based on a few fantastic reviews. I also have a Hitachi 65" rear projection HD ready monitor. The set-top box is a Magnavox HD tuner with built in DVR supplied by my cable company.
If any of you have any idea how I *should* hook this system up, I'd appreciate the advice. Otherwise any idea as to what options I have for getting all three component devices connected simultaneously would be greatly appreciated. BTW, both the DVR and TV have DVI connections, but the TV's DVI connection is on Input 1, one of the two component video inputs.
TIA,
Wojo
TIA,
Wojo
