TI-83+ Graphing Calculator: Questions
Discussion in 'Archived Threads 2001-2004' started by Andrew V, Sep 6, 2001.
  1. Andrew V
    Andrew V Stunt Coordinator
    May 11, 2000
    197
    I just got this calculator and I have a couple of questions:
    - How would I go from a standard number (6,250,000) to a scientific notation (6.25 X 10 ^ 6 or 6.25e6)? I know how to go from Scientific to Standard but not the reverse.
    - Where would I store formulas? Should I put it under “Programs”?
    - How do I delete a Program that I’ve already created?
    - Where can I find some games? [​IMG]
    Thanks in advanced for your help.
    ~Andrew~
    ~Pronto Programmer~
    AIM SN: FFU Productions
    ICQ #: 21603991
    Home Theater Pictures
    Equipment List | My Growing DVD Collection
  2. fredl
    fredl Extra
    Nov 1, 1998
    24
  3. Joe D
    Joe D Supporting Actor
    May 21, 1999
    838
    The TI-89 calculator is one of the best pieces of equipment invented.
    Most of your questions can be answered by looking at the manual for the calculator. I don't play games since that would distract me to much in class.
    Joe Dahlen
    "Take hold of the flame, you've got nothing to lose, but everything to gain."
  4. Andrew V
    May 11, 2000
    197
    Fred: Thank you for the link.
    I tried looking through the manual and the software manual but I wasn't able to find my questions.
    I actually have the "TI-83 +". Sorry for that mistake.
  5. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    Hrm. I have a TI83 around here somewhere I think. I have an 83 and a 92, I'll try to track down the 83 and refresh my memory to answer your ?'s if I can.
  6. Joseph S
    Joseph S Cinematographer
    Dec 23, 1999
    2,862
    My trusty ole '82 and '86 have a "Mode" menu where you select between "Normal" "Sci" and "Eng"
    I guess your option is to choose Sci and do the e6=10^6 in your head if you need it. I'm not sure you can pick to translate(?bad usage here?) between Sci and Normal. It's just one or the other.
    You can always switch back and forth. Once you get the answer, all you need to do is change the mode and push enter it should give you the desired result.
    As for formulas they would go into programs, but my 86 has almost every formula and conversion I ever needed to use built-in.
    I have no idea where to look for the games, it's been about seven years or so since I used it for that purpose.
    Don't you go cheatin' though. It may be tempting, but it's not worth it!!!! They really ought to outlaw these things. I remember playing arachnoid and blackjack throughout calculus class for a week or so. [​IMG]
  7. Andrew V
    May 11, 2000
    197
    Joseph: Thank you for your help. Switching the mode to “Sci” and just hitting enter did the trick. Don’t worry I won’t cheat. I would rather get a bad grade and learn from my mistakes then to cheat and not know the information. My math teacher lets us use Formulas during a Test so this isn’t considered Cheating.
    Philip: I appreciate you looking for your Calculator so you can help me out.
    I was able to find some games at: www.ticalc.org. I was able to figure out how to Delete Unwanted Programs.
    I have a few more questions:
    - What is the difference between storing something on the RAM or on the Archive?
    - What are the L1-L6 Buttons for? They are the Second Functions above Keypad Numbers: 1-6.
    - What would be the proper sequence for using the “Sci” Command? I found it by entering into the “Catalog” and hitting “S”.
    ~Andrew~
    ~Pronto Programmer~
    ICQ #: 21603991
  8. Joe D
    May 21, 1999
    838
    Whoops, read 89 for 83.
    Joe Dahlen
