The "R Value" of Pool Noodles
Discussion in 'After Hours Lounge (Off Topic)' started by Jay H, Nov 28, 2006.
  1. Jay H
    Jay H Producer
    Mar 22, 1999
    5,678
    32
    Pittsfield, MA
    Jay
    Strange thought last night... Do you think those pool noodles have any insulating qualities in them. I can typically find a ton of those things in people's trash and they are (or most of them) hollow. I have a bunch of copper pipes that could be insulated and it could be a free way of insulating them... Just a strange thought since the kind that I have bought are simply foam tubes. Of course, the pool noodles are thicker but if used in areas not pressed with space, they could be a free way of insulating pipes. Plus they come in cool flourescent colors, not dark grey! [​IMG]
    Jay
  2. MarkMel
    MarkMel Screenwriter
    Nov 19, 2003
    1,790
    84
    That's a good idea and I think that the pool noodles are made of the same if not very similar foam as some pipe insulation.
  3. DougR
    DougR Second Unit
    Jun 15, 1999
    354
    and you won't bang your Noggin on the pipes,when stumbling around in the basement ! [​IMG]
  4. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    I think so long as they fit snugly around the pipe it would be just fine. Now we'll hear how all your bills are under $10.
  5. LewB
    LewB Screenwriter
    Feb 11, 2002
    1,282
    2 important things to keep in mind:
    1) Match the ID (inside diameter) of the 'noodle' with the OD (outside diameter) of the pipe.
    There ought to lots of comedic value to 'what's the ID of your noodle' ? [​IMG]
    2) Since the noodles come in many colors, make sure that they don't clash with each other or the decor of the basement/garage/crawlspace where the pipes are. [​IMG]
  6. Matt Stryker
    Matt Stryker Screenwriter
    Oct 12, 2000
    1,313
    Also make sure they won't melt. For cold water pipes that might not be a problem though.
  7. MarkHastings
    MarkHastings Executive Producer
    Jan 27, 2003
    12,013
  8. Dennis Nicholls
    Dennis Nicholls Lead Actor
    Oct 5, 1998
    8,785
    311
    Boise, ID
    Dennis
    The only problem could be if they start to melt when in contact with a hot water pipe full of hot water. Why don't you cut off a chunk and throw it into some hot water to see the reaction?
    Hey, also take another chunk and try to burn it with a match. IIRC the store-bought pipe insulation is fire-retardant.
  9. Jay H
    Jay H Producer
    Mar 22, 1999
    5,678
    32
    Pittsfield, MA
    Jay
    I've found out from a home forum that the polyethylene stuff you buy at the hardware store is basically the same stuff as the pool noodles. The polyethylene stuff is rated to 160degs and not as high as some of the more expensive pipe wraps but it's fine for domestic hot water lines which shouldn't be that hot and cold water lines.
    Sounds like a great reuse of them. Now to go scrounge the neighborhood! [​IMG]
    Reduce, Reuse, Recycle!
    Jay
  10. Dennis Nicholls
    Oct 5, 1998
    8,785
    311
    Boise, ID
    Dennis
    Sounds downright unamurrican. [​IMG]
    you are the pool noodle in the venison salad of life....
  11. MarkHastings
    Jan 27, 2003
    12,013
    The only thing I'd worry about is if they use any type of sealer on the foam to make them water resistant. Hopefully that stuff isn't too flammable.
    and if they've been used in someones pool, what would the ramifications be if they had chlorine soaked in the material?
  12. McPaul
    McPaul Screenwriter
    Apr 1, 1999
    1,782
    48
    Vancouver
    Paul M
    what are "pool noodles"?
  13. Jay H
    Jay H Producer
    Mar 22, 1999
    5,678
    32
    Pittsfield, MA
    Jay
    http://www.tundrafoam.com/water_toys...oys_index.html
    Interesting enough, the link above shows that the same company that makes these Pool Noodles also makes pipe insulation.... Gee, I wonder if it's the same material...[​IMG]
    I already have about 3 of them lying in my basement, they make very good cushioning for my kayak to keep it off the floor...
    Jay
  14. Jay H
    Jay H Producer
    Mar 22, 1999
    5,678
    32
    Pittsfield, MA
    Jay
    I cut the noodles this morning (my day off) and put them on. they are a bit harder to install than the store bought kind because they're stiffer and thicker but they fit perfectly around my copper pipes and they are great!!! Now I just need to find some more lying around. They're not any cheaper than the store bought kind cause you can buy the preglued ones from Frost King in a pack of 4 I think 4' lengths for like $5 or so, but the kicker is that I can find a ton of these in the trash that people throw out so its free for me. I just need to probably wait for next summer when people start tossing them again.
    Jay
  15. MarkHastings
    Jan 27, 2003
    12,013
    Do you have any physical therapy places near by? The ones that have pools, use them a lot. You could inquire about getting the ones they throw out.
  16. Jay H
    Jay H Producer
    Mar 22, 1999
    5,678
    32
    Pittsfield, MA
    Jay
    ..or I can feign a shoulder injury and infiltrate the local PT place...... [​IMG]
    Maybe the next James Bond film should be infiltration of a PT place to smuggle pool noodles out...
    Jay
  17. McPaul
    McPaul Screenwriter
    Apr 1, 1999
    1,782
    48
    Vancouver
    Paul M
    hmmm... pool noodles. you learn something everyday!
  18. Brandy S
    Brandy S Stunt Coordinator
    Mar 24, 2006
    116
    Brandy Storey
    Yup, same stuff. I worked at a production facility that made pipe insulation five days a week and pool noodles the other two (the weekend) with lower output. I got a ton of free ones because you get some funky colors (alot of browns!) when we switched color beads (the stuff melted to make the tubes).
    Not sure about R values or usability as that was about ten years ago!
  19. MarkHastings
    Jan 27, 2003
    12,013
    Oh good, then you can answer my question about whether the pool noodles had any type of extra coating that the pipe insulation didn't....although I guess you did answer that by saying they were the same, but just wanted to be sure.
  20. Jay H
    Jay H Producer
    Mar 22, 1999
    5,678
    32
    Pittsfield, MA
    Jay
    COOL, thanks Brandy. I had an inkling of the fact when I came across a mfgr website which also mfgred pool noodles as well as pipe insulation.
    So, I guess this also means that to a degree, pipe insulation can be used as pool noodles! [​IMG]
    In thought, since insulation is trapped cells of air (to give it an R value), it would naturally have "floating" qualities for air is lighter than water so naturally it follows that the insulating pipe insulation should float and the pool noodles should also insulate.
    There are open cell foam out there but that is now what the pool noodle or pipe insulation are made of. Brandy can surely explain this better.
    Jay
