T-Nuts, yes or no with Birch ply (1 Viewer)
JohnA
I will be using void free birch plywood as suggested by Adire for their reference designs.
The question I have is do I need to use T-Nuts with plywood or can I just mount the driver by screwing directly into the plywood.
-JohnA
Julian Data
T Nuts grab better in plywood. If you plan on removing the driver(s)/PR(s) occasionally, then install the T Nuts.
Dean Cooper
I would use T-nuts for ply. best way to install them is to pull them into place with a screw and washer...insures a nice straight installation.
Dean
acinstallation715
