SVS orignal driver, questions (1 Viewer)
Geoff L
Geoff
The only params I have for the orignal SVS's 12" driver....
FS-21
Qts-.38
Qes-.39
Qms-6.6
Vas-4.6 cf
Re-3.2
Are these values I found in prior posts correct?????
Also might someone have the (X-max), (power handeling) and (SD)????
Have 2 and looking to put them car bound, more than likely sealed....
Regards
Geoff
I believe those are ones Tom V. posted previously. Those are the ones I'm using anyway.
Does anyone know the required cut-out diameter for the original SVS driver?
Geoff L
Geoff
Scotty
My first 2 SVS drivers are at a friends shop right now {30 miles away} so can't give you a cut out measurment. :frowning: I have not even took them out of the shipping box yet! I just picked up two more drivers from a HTF member, though their not here yet. So im not muchofa help. :b
Till then you might try Pats page where he built a sub around the original SVS driver. He may have it listed in his design. Or E-mail Pat directly, Im sure he would be kind enough to provide it for you.
Geoff
Patrick Sun
Those were the values I used to model for the box/tuning.
Click on the SBS link in my signature for the "SVS driver in a box" project I completed over a month ago.
IIRC, the cutout is around 11" in diameter. But as always, it's best to have the driver in your hands, measure it, and then cut the hole for it.
Joe Meissner
just did a sub using the SVS driver and the cutout was 11 1/8". i had it cut at 11" and had to sand the heck out of it to finally make it fit.
blitz
