Or you can buy blanket batting at the local fabric store and use 3M spray glue to mount it. The batting I used was about 3/4" thick. I trimmed it to the length of the tube and then glued/rolled the tube until I had several layers built up. Dan W recommended about 8#'s total. HTH...Mike
