Speaker wall mounts for apartment
Discussion in 'Home Theater Projects' started by perrin, Feb 19, 2004.
  1. perrin
    perrin Stunt Coordinator
    Sep 15, 2001
    106
    Does anyone know if a speaker wall mount will cause a lot of damage to a wall? I live in an apartment, and I think it would be easier to get speaker stands. Can anyone offer a suggestion?
    perrin
  2. Jason Edgecombe
    May 13, 2002
    40
    Depends how big/heavy your speakers are. Most can probably be hung on wall mounts using 2-3 screws or drywall anchors. The holes can be spackled and sanded down on move out without too much trouble, but you may run into problems with mismatched paint, then your landlord getting suspicious over what you've done, etc. ...
  3. perrin
    Sep 15, 2001
    106
    Thanks, Jason. I may just go with speaker stands since I do not want to go through that kind of hassle.
    perrin
  4. Dustin Harrison
    Dustin Harrison Stunt Coordinator
    Jan 14, 2004
    96
    Some small holes are expected and most apartments repaint and spackle after people move out anyway.
    You can pick up some good wall mounts at Home Depot for $20. That's what I'm using and they work great.
  5. perrin
    Sep 15, 2001
    106
    Thanks for letting me know that Home Depot carries speaker wallmounts. Do you know what their model number is?
    perrin
  6. Dustin Harrison
    Jan 14, 2004
    96
    Sorry I do not. I believe they only have one model for speakers.
