Speaker Stands - Sand or Cement Fill?
Discussion in 'Archived Threads 2001-2004' started by Todd McF, Jul 17, 2001.
  1. Todd McF
    Todd McF Second Unit
    Jul 5, 2001
    285
    Hi,
    I've been building 15 inch speaker stands with square oach risers (measuring 3x3 inches internally). I bought cement for fill, but I wanted to check to make sure that was the way to go.
    Should I just use the cement unmixed or go ahead and mix? Should I use sand instead? Any reasons? Sound dampening properties etc?
    I appreciate any advice. Thanks,
    - Todd
  2. DonnyD
    DonnyD Screenwriter
    Jun 12, 1999
    1,154
    IMHO, I would not use cement. Sand or shot is the preferred method with shot being tops. If you mix the cement, it will be hard to remove or change. Leave your options open. Sand is cheap and shot will be higher but better.
  3. Todd McF
    Jul 5, 2001
    285
    Thanks for the reply. In your opinion, how is unmixed cement inferior to sand?
  4. JerryIII
    JerryIII Stunt Coordinator
    Nov 9, 1998
    123
    Where is a good place to buy shot? I have also heard that kitty litter works well.
    Jerry
  5. Todd McF
    Jul 5, 2001
    285
    It seems to me that density is the key, so mortor or cement (unmixed) is better than sand or kitty litter. By that token, lead shot is better than mortor or cement.
    Can anyone confirm or give a differing opinion? I'm sealing up these babies tonight so please let me know!!!
  6. Mike E W
    Mike E W Agent
    May 7, 2001
    26
    I can say from personal experiance that if you have a cat that uses a litter box you do not want kitty litter in your speaker stands. Having learned that lesson I used aquarium gravel. Dont know how it rates as far as being an optimal material but its cheap its heavy its clean and its easy to use.
  7. DonnyD
    DonnyD Screenwriter
    Jun 12, 1999
    1,154
    Being a remodeling contractor, I try to stay away from concrete/cement work if at all possible !!!! LOL
    Actually, cement will have a "dustiness" that may be hard to keep in the enclosure and out of electronics. Also, the chemicals in cement may be something to consider around your enclosure.
    Shot can be found at some firearms stores. Sand is actually recommended (along with shot) by some speaker manufacturers to "load" speakers, providing more mass and anchoring.
    IMHO, sand will do almost as well as shot. When I loaded my speakers, I put sand in ziplock bags first, then into the enclosure.
  8. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,166
    " In your opinion, how is unmixed cement inferior to sand?"
    Donny's right, cement will be dusty but also, unmixed, it'll harden harden anyway (eventually) due to humidity in the air. I'm a Union Cement Mason..
    - Chip
  9. Phil A
    Phil A Producer
    Oct 1, 2000
    3,123
    30
    Central FL
    Phil
    You can get fine lead shot at a gun shop. Be very careful handling it, do it outside or in a well ventilated area, wear gloves and wash up afterwards. Don't handle it and then eat or smoke.
  10. JerryE
    JerryE Agent
    Apr 2, 2001
    30
    Phil,
    Since you're in Sterling and I'm in Fairfax (until next month at which time I'll be in Ashburn), can you recommend a shop locally to pick up some lead shot and a particular density to get?
    I'm not exactly the type who frequents gun shops so I'm a little out of the loop [​IMG]
    Jerry
  11. Matt Heebner
    Matt Heebner Stunt Coordinator
    Jul 2, 2000
    247
    I filled my stands with aquarium gravel as well. The stands are definitly heavy enough, and the gravel is not dusty at all. The gravel is cheap and even comes in varying sizes from bigger to fine.
    Matt
    Sony DB930
    Pioneer DV-525
    Mitsubishi WS55807-Widescreen baby!!
    Paradigm Titans-mains
    Paradigm Atoms-surrounds
    Paradigm CC-170-center
    Velodyne CT-120-subwoofer
  12. Phil A
    Phil A Producer
    Oct 1, 2000
    3,123
    30
    Central FL
    Phil
    Jerry don't know much about guns either. Looked in the yellow pages and went to a shop in Leesburg. I have 2 Target audio racks, one sitting waiting for me to get to the basement. I filled one with Target's heavy metal stuff that was about $80/bag and used mostly lead shot and some sand to fill the other. I believe it was no. 8 or no. 9 lead shot and was like big sand grains and came in 25lb. bags that were $19.99 each. The bag was around the size of an 8.5x11 inch piece of paper.
  13. JerryE
    JerryE Agent
    Apr 2, 2001
    30
    Thanks, Phil. I had a feeling you were going to say Leesburg [​IMG] That's exactly what I was hoping to find out (size, price, etc).
    [Edited last by JerryE on July 17, 2001 at 09:17 PM]
  14. Vince Bray
    Vince Bray Stunt Coordinator
    Oct 4, 2000
    170
    I filled my 6" cardboard tube speaker stands with sand and while shot may be better, IMHO the cost is probably out of proportion to the improvement. The stands are very heavy, very dead to the knock, and the sand cost.... um, $3.00.
    I baked the sand in a large turkey pan for a while before filling.
    Also, they are very kid-proof. When they are that heavy, it just is impossible for a small child to pull/knock them over. Very high SAF.
    You could always upgrade to shot...
  15. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,166
    " I baked the sand in a large turkey pan for a while before filling."
    LMAOOOOOOOOO......... Did ya baste it and stuff it too?
    - Chip
  16. Phil A
    Phil A Producer
    Oct 1, 2000
    3,123
    30
    Central FL
    Phil
    Jerry - all you need to do is borrow an old pick-up truck and fill it with empty beer cans and not shave for a couple of days and wear some kind of animal skin and you don't have to worry about looking out of place.
  17. Bob_M
    Bob_M Stunt Coordinator
    Apr 3, 2000
    195
    Hi Guys,
    I used sand in my speakers stands and it worked fine. I did consider shot but the expense and safety shied me away. One item I never did consider was Stone Dust. I wonder if that is heavier than sand?
    Bob
