Speaker Covers (1 Viewer)
DavidEC
OK I know that you guys might laugh but...
Is there a (white [that can be dyed to match color of paint]) cloth cover that I can cover a set of 'black box' souround speakers with out 'blocking' the sound.
'IF' so where can I purchase it from?
--David
GarryW
What type of surounds are they? You may be able to use spray paint on the cabinet and you can buy white grill cloth, I think.
DavidEC
Gary -
They are the 'low priced' Kenwood speakers... and front does not 'snap' on or else I would already of thought of that...
_OTHER_ than the point that you really don't want me near spray paint...
--David
DavidEC
BUMP
Sorry guys but I am really looking for an answer other than spray paint...
--David
Westly T
Why not cover the black boxes (boxes only, not front of speaker) with a thicker white cloth or adhesive paper (like shelf paper), then cover the entire speaker with a white speaker grill cloth? The reason for the first layer over the boxes only is because most speaker grill cloth will allow the black to show through.
- Wes
My Home Theater
The MMG were replaced with 1.6QR's and added Marantz MA-700's. SVS is here. Ok, allot more then that has changed, I'll update my page some day...
DavidEC
Westly T -
Wherecan I get 'White Speaker Cloth'??
All I can find locally is either brown, dark grey, and black but no white...
Or what type of cloth from 'JoAnns' (ClothWorld) can I purchase that would be 'sound clear'?
--David
Joshua32
