speaker and receiver question
Discussion in 'Beginners, General Questions' started by ments8, Oct 15, 2006.
  1. ments8
    ments8 Auditioning
    Oct 14, 2006
    4
    Last year I purchased a home theatre in a box system, the Sony DAV-DZ100. Due to lack of digital inputs I am buying a receiver. I want the Sony STRDG500S. My question is whether or not it is possible to keep the speakers that came with my original system and use them with the receiver? If it is possible, how can it be done?
    Here are links to both products:
    http://www.sonystyle.ca/commerce/ser...ductId=1001242
    http://www.sonystyle.ca/commerce/ser...h=n32100n32104
    If this is possible it would save me a lot of money from buying new speakers.
    Any help at all would be appreciated.
  2. Seth=L
    Seth=L Screenwriter
    Jul 17, 2006
    1,313
    The subwoofer is an issue for sure. It does not have it's own amplifier and relies on the HTIAB to provide it with power. However the Receiver you are looking at cannot perform that function, powering the sub. There aren't many receivers capable of powering a sub, I have not seen one in a long time other than other HTIAB systems.
    The 5 speakers are easy, just disconnect the cables from the speakers and get some 16 gauge wire in a spool to wire those up.
    It all depends on how much money you want to spend really. For less than $1000 you could have a very respectable system.
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,041
    17
    Katy, TX
    Wayne
    Shouldn’t be a problem. If the speakers from the DAV came with speaker wires with plugs on them, you can cut them off and strip back the wires to connect to the new receiver. If the sub doesn’t have a built-in amp, you can use the DAV as the amp.
    Wayne A. Pflughaupt
  4. JeremyErwin
    JeremyErwin Producer
    Feb 11, 2001
    3,219
    hmm:
    passive subwoofer. That's a problem.
    Impedance: 2.7 ohm: that's a problem.
    No, I'm afraid that most receivers are designed for use with 8 ohm speakers and active subwoofers.
    Any particular reason you want a Sony STRDG500S?
  5. Wayne A. Pflughaupt
    Aug 5, 1999
    6,041
    17
    Katy, TX
    Wayne
    What's 2.7 ohms? If it's the sub, it's not a problem -the old HTIB can be the amp for it.
    Wayne A. Pflughaupt
  6. JeremyErwin
    Feb 11, 2001
    3,219
    Sony Style Canada
  7. Wayne A. Pflughaupt
    Aug 5, 1999
    6,041
    17
    Katy, TX
    Wayne
    Ouch... [​IMG]
    Wayne A. Pflughaupt
  8. Seth=L
    Seth=L Screenwriter
    Jul 17, 2006
    1,313
    That doesn't help Sony's rep, cough! bad rep cough!
    I would go with new speakers, you will thank yourself later. Insignia NS-B2111 bookshelf speaker air awesome for $50 a pair.
  9. ments8
    ments8 Auditioning
    Oct 14, 2006
    4
    Thanks everyone for your replies. There is no reason I chose the Sony other than the price seemed pretty good. I really don't want to spend a lot of money as I just purchased an Xbox 360 (the reason why I want a receiver in the first place). So what I am taking from your responses is that I just need to get a new sub and keep the same speakers.
    I don't understand the Impedance issue though.
    If anyone has any other recommendations/workarounds it would be helpful. Thanks.
  10. ments8
    ments8 Auditioning
    Oct 14, 2006
    4
    I was just checking the prices for subwoofers and I can't really spend that much money at this time.
    How is it possible to use the DAV as the amp? Would this still allow for 5.1 discrete audio?
  11. JeremyErwin
    Feb 11, 2001
    3,219
    Low impedence speakers (1--4 ohms) can cause some amplifiers to either shut down, or generate a lot of heat, possibly leading to fires.
    A few receivers are designed with low impedence speakers in mind-- but harmon-kardon, NAD, etc. are probably out of your price range.
  12. Wayne A. Pflughaupt
    Aug 5, 1999
    6,041
    17
    Katy, TX
    Wayne
    Assuming the DAV has some kind of line input (“Video,” “Aux,” “CD,” etc.) you can run the new receiver’s subwoofer output to that input on the DAV. Then connect the sub as you had it before.
    Wayne A. Pflughaupt
  13. ments8
    ments8 Auditioning
    Oct 14, 2006
    4
    Again thanks everyone for the info. I knew keeping the speaker set was to good to be true.
    I am now thinking of purchasing this speaker/receiver set. I hear good things. Let me know what you guys think. They cost around $270 USD.
    Thanks.
    http://www.spherexinc.com/products_xbox51.aspx
