Tony DL
- Nov 27, 2002
Recently my cable company has offered digital cable to my area. After about 6 months I finally received a box with S-Video and Digital audio outputs. The cable box has two options. 1) optical output and 2) SPDIF coax output. My digital receiver has two options, 1) optical input (which I have my DVD player hooked up) and 2) PCM inputs. Can I hook the SPDIF output from my cable box to the PCM input on my receiver. If so what is the difference between SPDIF/PCM/Dolby Digital 5.1. I have read in the forum about the technical formats etc. but have not been able to find a comparison between the three. Example, Will SPDIF and PCM produce a 5.1 channel surround sound if it has a digital feed from the source? Which has the best sound, etc.? Is there any other option since my receiver is limited to the one opticial input (which is hooked up to my DVD)and two PCM inputs? Can anyone help with this problem?
Tony
Tony
