SoundBlaster Live 5.1 & XP problems
Discussion in 'Archived Threads 2001-2004' started by Luis Esp, Nov 11, 2001.
  1. Luis Esp
    Luis Esp Supporting Actor
    May 25, 2001
    583
    I've using the SoundBlaster Live 5.1 sound card with XP, using the driver updates on their page. Everytime I start up XP, the sound is distorted and I have to use Creative Restore Defaults to correct the sound.
    Does anyone have any ideas on to correct this situation?
  2. Arthur Legardo
    Arthur Legardo Second Unit
    Jul 21, 1999
    441
    Have you tried using the drivers that came with your card and then running the XP update from Creative Labs? Also, check your device manager, are there any exclamation marks? The only problem I've had with my Platinum 5.1 and XP (Pro) was the typical VIA motherboard popping noise, that was until I installed the 4.35 VIA drivers.
  3. Luis Esp
    May 25, 2001
    583
    That's how I installed the sound card. I went to the device manager and noticed that the drivers for the original motherboard audio is still present. Should I remove those drivers? I've tried plugging the speakers into the original computer outputs, but they no longer give me any sound.
    Thanks in advance.
  4. Arthur Legardo
    Jul 21, 1999
    441
    First off, disable the on-board audio in the BIOS and then remove them from the device manager.
