Sound & Vision ? (1 Viewer)
ChadLB
I couldn't find any links to this but is the setting 75db or 85db on the Sound & Vision? For me the only difference will be if it is 75 which I have been using then the volume will stay at -32 now but if it is 85 then the volume will go to -22....thanks for the help...
John Gido
I e-mailed S&V with the same question and was informed that, because their set-up disc was manufactured by Avia, the correct is 85dB.
ChadLB
Hey John,
Thanks for the info...I always thought it was 75 but wasn't sure and someone else had mentioned they thought it might be 85.
acinstallation715
