How many watts is your power supply? It should say on the power supply itself. Ideally, you want a 300w or higher one, though there are some lower powered ones that have high enough +3.3v and +5v rails to support it.
In case you're not already aware, remove *ALL* traces of your old video card drivers BEFORE installing the new card and drivers, otherwise you'll have endless headaches.
