Sony DA4ES makes hum inside
Discussion in 'Playback Devices' started by Scott_Haslip, Sep 17, 2003.
  1. Scott_Haslip
    Scott_Haslip Auditioning
    Sep 2, 2002
    My 2 month old Sony DA4ES now has an audible hum coming from inside the chassis. There is absolutely no hum from any of the speakers, and the unit appears to be working perfectly.
    I can't honestly say whether it just started, but I clearly noticed it when I turned it on tonight. I suspect it just started.
    The unit does not have an internal fan. It sounds like an electrically induced hum.
    I will try to unplug every input and output and see if it ceases.
    Bottom line, anybody out there have a Sony DA4ES or similar unit in the ES line that has a slightly audible hum?
    I need to know whether I should perhaps get it returned or serviced.
    Thanks in advance for any input.
  2. JackS
    JackS Supporting Actor
    Jan 17, 2002
    Transformer hum is common to the 777es that I have and probably common to all ES receivers. Someone had stated a couple of years ago that they successfully isolated the transformer from the chasis using rubber washers but, unless this is really an audible nusance ,I'd ignore it.
