Brett_A
- Dec 18, 2000
I am almost ready to start finishing my 81s and I choose some Formica(blue and black to match my 281s) Depending on how this turns out I will probably refinish them as well.
I did some searches and didn't find all the answers I needed. First I will cut the laminate big on the edges and then cut it close with a router? I am going to need a bit for my router but which one(flush trim, laminate?) I am a little unsure on how to use the bits as well.
Anything else I should look into buying to make my job easier? Do I need a mask for solvent based contact cement? How about any links. TIA
Brett
Brett
