Software or Hardware Test Tones?
Discussion in 'Archived Threads 2001-2004' started by Jimmy Gonzalez, Aug 24, 2001.
  1. Jimmy Gonzalez
    Jimmy Gonzalez Stunt Coordinator
    Aug 21, 2001
    52
    Should I calibrate my system with the test tones found on Video Essentials DVD or from the test tones on the Denon 3802? Will it effect DTS if I use VE?
    J.G.
  2. Jimmy Gonzalez
    Aug 21, 2001
    52
    Does anyone have an opinion? I have been using the pink noise from the Denon But I read some people are using the ones from VE.
  3. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,715
    I would say, try both, and see what you think sounds better.
    I don't know why this is the case, but if I use VE or Avia, my sub ends up way too loud. So I use the tone generator in my pre/pro.
    (I have all my speakers set to small with an 80 Hz crossover to my sub.)
  4. Mike Sheahan
    Mike Sheahan Stunt Coordinator
    Jul 25, 2001
    57
    What about the 6th and 7th chanel?
    VE doesn't send signals for those speakers.
    Is there a DVD that does?
  5. Jimmy Gonzalez
    Aug 21, 2001
    52
    Thanks a lot guys, I am going to try it out now.
    J.G.
