Andrew Sleight
Grip
- Dec 28, 2003
I have a very simple HT setup which I have installed over the last few days. Now I am getting greif from the Domestic Goddess on how to simply control it all and not have to use all the different controllers.
The new receiver is a Pioneer 712 and has the ability to control other devices. The issue is:
My video is a NEC (possibly rebadged LG) and does not appear on the code list sheet for the receiver:frowning:
My analogue Pay TV box is inbranded as it is provided by the cable company
My projector is LG and does not appear on the code list for the receiver :frowning:
The next model up in the Pioneer range is 812 features a programable remote control.
Do you think I should return the 712 and get a 812? (difference approx $140) This would also give me 6.1
OR
Should I go buy a programable remote control?
Suggestions? Comments? Brands and models?
Many thanks
Andrew
OR
Many thanks
Andrew
