Should we distinguish between OAR and TAR...?
Discussion in 'Archived Threads 2001-2004' started by Artur Meinild, Aug 25, 2001.
  1. Artur Meinild
    Artur Meinild Screenwriter
    Aug 10, 2000
    1,294
    TAR = Theatrical Aspect Ratio.
    The reason I'm asking is because lately, I've seen some confusion (on this forum) to whether or not certain movies are released as the director intended...
    One example is Evil Dead. To my knowledge, this was shown 1.85:1 theatrically (I'm not sure), and this AR is recreated for the new DVD release. However, all previous HV versions have been 1.33:1, which is the films OAR. Some people complain about the new DVD being 1.85:1.
    Another example is of course Kubricks films, which is much the same situation. Eyes Wide Shut for instance was shown 1.85:1 theatrically, but released on HV as 1.33:1 because he wanted that. This is the opposite situation, as lots of people complain about the DVD *not* being 1.85:1.
    A last example is Toy Story, which had a TAR of 1.85:1, but now has a OAR of 1.77:1 (directors intend). No one seems to complain about this, yet some people find room to complain about the new Silence of the Lambs being 1.77:1 instead of 1.85:1 as shown in theaters!
    So maybe we should clearly distinguish between OAR and TAR (which of course in most cases would be identical), since movies *can* be "butchered" against the director's intend both in theaters and on video...
    ~ Stud. Polyt. ~ Artur Meinild ~
  2. Adam Tyner
    Adam Tyner Screenwriter
    Sep 29, 2000
    1,410
    The Evil Dead was framed for 1.66:1 and probably shown that way theatrically in Europe. More than likely, it was matted to 1.85:1 stateside. According to The Evil Dead Companion, a book Raimi participated in heavily, the only full-frame showing was the premiere, and that was because they showed the film in a theater that accomodated that older aspect ratio. The 1.85:1 image on the upcoming disc may have the same aspect ratio, but it was reframed, shot by shot.
    My DVD list | My personal site
    [Edited last by Adam Tyner on August 25, 2001 at 08:26 AM]
  3. Dana Fillhart
    Dana Fillhart Supporting Actor
    Feb 8, 1999
    977
    First I was hit with an OAR.
    Then I was MAR'd.
    Now I've been TAR'd.
    This is beginning to hurt a lot! Pretty soon, I'll be GOR'd too!
    [​IMG]
  4. Richard Kim
    Richard Kim Producer
    Jan 29, 2001
    4,385
    There's Apocalypse Now with a TAR of 2.40:1 but is shown 2:1 on home video at the insistance of the DP.
    There also Galaxy Quest, with multiple aspect ratios theatrically, but with one AR for home.
    [Edited last by Richard Kim on August 25, 2001 at 09:12 AM]
  5. george kaplan
    george kaplan Executive Producer
    Mar 14, 2001
    13,063
    2
    Perhaps you'll be BAR'd (Butchered Aspect Ratio), CAR'd (Crappy Aspect Ratio), FAR'd (F*cked-up Aspect Ratio), JAR'd (Just plain wrong Aspect Ratio) or WAR'd (Weird (and clearly wrong) Aspect Ratio).
    [​IMG]
    13-time NBA world champion Lakers: 1949, 1950, 1952, 1953, 1954, 1972, 1980, 1982, 1985, 1987, 1988, 2000, 2001
  6. Artur Meinild
    Aug 10, 2000
    1,294
    Thanx Adam, I certainly believe you're right!
    And yes, Apocalypse Now is a very good example, I completely forgot about that one.
    BTW, it just hit me that TAR goes for Television Aspect Ratio as well. Several TV shows that have an OAR of 16:9 is cropped to a TAR of 4:3! [​IMG]
  7. Adam Lenhardt
    Adam Lenhardt Executive Producer
    Feb 16, 2001
    17,066
    1,786
    Albany, NY
    Also, with Toy Story, from what I've heard, that was originally animated at 1.77:1 and was cropped to 1.85:1 for common projection reasons. Silence of the Lambs was filmed at an aspect ratio of 1.85:1, so that really is a problem, just like the DVD release of 'Batman'
    My DVD Collection
  8. Patrick McCart
    Patrick McCart Lead Actor
    May 16, 2001
    7,520
    149
    Alpharetta, GA, USA
    Patrick McCart
    Here's what they mean to me:
    Original Aspect Ratio: The entire image on the negatives.
    Theatrical Aspect Ratio: What was intended to be seen in theaters. A 1.33:1 filmed film shown matted, too.
    Modified Aspect Ratio: Any image that differs from the negatives. For example, Willy Wonka was modified in theaters (matted) but the OAR appears on the current SE DVD.
    Matted: Turning a 1.33:1 film to 1.85:1 to simulate the intended theatrical image. Most 1.85:1 films were filmed at 1.33:1 only...excluding the few that are hard matted and/or feature CGI effects. CGI is usually rendered at the theatrical aspect ratio, thus those shots are hard-matted to save money, time, and effort.
    Pan & Scan: Only hard-matted 1.85:1, films with CGI (1.85:1 and Super-35), and ALL anamorphic or 55mm to 70mm films are truly pan & scanned on 1.33:1 versions. A 1.33:1 version of Wonka is the OAR, the matted version is the TAR. The 1.33:1 version of Amadeus is both a MAR and P&S image. The letterboxed version is the OAR and TAR.
    Chances are...if you're seeing a film on TV that was made after 1955 and is taking up the full screen, it's either panned and scanned or open matte.
    Of course, there's that process Pixar used on A Bug's Life...
    I prefer the theatrical aspect ratio. It's no surprise to me that I have 0 pan & scan-only films and only 2 open matte-only discs (Vegas Vacation and Help!...which the latter is in dire need of a new transfer...)
    P.S.: There's no P.S.
  9. Scott H
    Scott H Supporting Actor
    Mar 9, 2000
    693
  10. PhilipG
    PhilipG Cinematographer
    Jan 13, 2000
    2,002
    Don't forget KAR (Kubrick's Aspect Ratio), which could be absolutely anything, depending on
    a) your TV shape
    b) whether you knew Kubrick at the time
    c) whether you believe what Kubrick's family says
    d) whether you prefer the open matte composition
    e) whether Warner thinks it can make more money with boxset version 3
    [​IMG]
  11. Hendrik
    Hendrik Supporting Actor
    Oct 23, 1998
    595
    "TAR = Theatrical Aspect Ratio. "
    ...this has come up before ... several, if not many times already...
    ...actually, after careful consideration, I have come to the conclusion that there is no way there is such a thing as "TAR"...
    ...if the baby must have a name, it should be named as follows:
    ITARE = Intended Theatrical Aspect Ratio (Europe)
    ITARU = Intended Theatrical Aspect Ratio (USA)
    ...to be entirely correct, then, there should be two re-re-releases of, say, Stanley Kubrick's "4:3" movies: one set for European anal retentives (ARs), featuring ITARE... and another set for North American ARs, featuring ITARU...
    ...incidentally, and - probably - ditto for Anchor Bay's releases of Paul Verhoeven's pre-Hollywood films, and many Chabrol/Polanski/Truffaut, etc. films...
    ...not-so-incidentally, and - definitely - ditto for all movies not filmed at the original, early nineteen thirties 'Academy aperture' 1.33:1 (a.k.a. OAA) but rather the improved, late nineteen thirties 'Academy aperture' 1.37:1 (a.k.a. IAA)... in fact, the latter should be windowboxed and anamorphized before being transferred to DVD, so that they will appear in their full, original glory on widescreen displays...
    ...and...
