Kimmo Jaskari
- Feb 27, 2000
Provided you get the proper internal volume to a DIY sub, how important is the shape of it? I'm talking about a traditional square sub from MDF.
Can you make it long, wide and flat or should it be more square in design to get the best results out of it?
Presumably a sub with larger/longer walls will need to be well braced internally to keep the walls from flexing, but are there other considerations as well?
/Kimmo
"Don't tell me; we're about to go over a huge waterfall?"
"Yep."
"Sharp rocks at the bottom?"
"Most likely."
"Bring it on."
/Kimmo
"Yep."
"Most likely."
"Bring it on."
