Searchable Database of Backup Discs?
Discussion in 'Computers' started by MarkHastings, Dec 1, 2008.
  1. MarkHastings
    MarkHastings Executive Producer
    Jan 27, 2003
    12,013
    I used to have this wonderful program for Mac (pre OSX) where you could put a CD data disc in and it would make a text listing of every file and save to a searchable database.
    This way you could search for a file and find out exactly which disc the file existed.
    Is there a program like this for PC? My main requirements would be:
    1. It has to work with DVD data discs.
    2. You simply pop the DVD disc in and let the software generate the database with a reasonable amount of clicks.
    3. The database can be searched and viewed by disc
    4. The database will list the folder structure as well
    5. Either free or fairly cheap (it's for work, so I have to convince my boss to spend the $$)
    6. The database can be searched by multiple computers
    Note: #6 isn't the most important part. The others would be. Of course, everytime I try to search for something like this I end up with those DVD video database programs.
