Richard_s
- Nov 25, 2000
With all the help all have given me in trying to help me with my satellite changeover from cable I still am undecided. This is the key issue that is perplexing me.
What resolution or picture quality can I expect.
I do not plan to go HDTV for as a minimum a few years so I am looking at just satellite for its Digital Picture and Digital sound. Based on my looking around at equipment its seems it will cost in the $200 range for Digital (optical output SPDIF) sound and S-video, $350-$400 for Digital sound and component video.
Ok here is what I just can not seem to understand. Even though my TV has a component video capability I have read what I thought stated that I would get an insignificant improvement over using s-video based on the lines of resolution available in non HDTV digital satellite signals.
Is this true?
What I seem to "hear" is that my digital cable even if I did have s-video out on the converter I would be limited to 330 lines and with satellite whether I have s-video or component video I will be limited to 440 lines of resolution. My TV is the Sony 53HS10 and has a line doubler (if that matters). It seems that when I go satellite I am wasting money If I pay extra for component video vs s-video based on the 440 lines of information limitation. Is my understanding way off base I am still confused
A second issue for me is 18 inch dual LNB vs 18x24 dual LNB dish. Again it seems that if I am not planning on HDTV with directv then all I need is the 18inch Dual LNB (in case I want to have more than one receiver). Unless there is a difference in reception quality using the 18x24 vs the 18 dish then the 18inch dish is all I need?Is this correct
Thanks all
Is this true?
Thanks all
