Sebastien R
Grip
- Nov 21, 2002
Hi, I just bought a RP-82 and I can't seem to be able to find the GAMMA CORRECTION setting mention in the specs on their the Panasonic website. Does the RP-82 have one or is it a misprint from Panasonic.
Also, can someone tell what is the 4:4:4 signal processing and does the RP-82 really have this fonction(it's in the specs on the website but not on the box or in the instruction manuel)
And finaly just to make sure, does the RP-82 equipped with the SAGE/FAROUDJA DCDi chip.
Thank you.
Thank you.
