DanaA
- Nov 21, 2001
Just remember Andrew, Canada gets a lot darker, quicker in the wintertime and I'd expect that post to be up by about 5:00 pm.
It also seems to me that the only way Rotel could use this article to justify its poor bass management would be in the unlikely event that the .1 channel content disappeared from every SACD and DVD-Audio disc out there. Until that happens, I don't believe that Rotel is addressing the bass management issue for such discs correctly.As I posted on the HTGuide forum which contains Rotel's letter, the LFE channel is a total red-herring. Even if DVD-A's and SACD's are mixed without an LFE channel, you're still going to have bass-doubling on the other channels. The only thing that the lack of LFE would do is provide you with a workaround, since you could disable the sub for multi-channel analog mode, that way you would get the full-range signal to your main channel speakers without discarding any LFE content. But that's a hack, a workaround, for the fact that Rotel bass management is fundamentally flawed for the analog inputs. I really can't see any possible justification for the bass-doubling approach. At the very least, stick an analog x-over in there like Outlaw did.
I agree that the rsp-1066 has a bass-management flaw : it doesn't behave like said in the manual.
But the bass-doubling issue might not be as bad as it may seem and may even be positive as I see at least one justification for it :
most studys about sub-woofers placement versus room interference, shows that the more subs you got, the less room resonances you get. In a practital approach, with 4 subs, you are close to ideal.
First article is here from a swedish company :
http://www.sonicdesign.se/subplace.html
Second one is more technically oriented and is from Harman Kardon :
http://www.harman.com/wp/pdf/multsubs.pdf
Let's say you have 2 main large speakers and 2 subs, with bass-doubling, your mains will also behave like subs, creating the 4 subs needed for a line source of infinite length.
I know it may sounds weird, but this bass-doubling issue may not be as bad as it looks afterall
Even if DVD-A's and SACD's are mixed without an LFE channel, you're still going to have bass-doubling on the other channels.Perhaps I'm being dense, but how would you still experience bass doubling without the LFE channel -- even with a subwoofer engaged? Unless there is more wrong with the Rotel 1066 than even I imagined, the bass from each channel should be directed to the subwoofer below the cutoff frequency you have set for "small" speakers (unless you have set them all to "large"). In theory, if you have all five speakers set to "large," you shouldn't get any bass to the subwoofer with a 5.0 disc, should you?
...if for any reason you have been sold some of those nasty little satellite speakers that cannot reproduce bass...By the way, is Rotel suggesting that those "nasty little satellite speakers" are the only speakers that cannot accurately reproduce bass? I've seen very few center and surround speakers that can reproduce deep enough bass -- even in THX speaker systems (which are usually set to "small" with an 80 Hz cutoff). Seems like the VP of Rotel needs to step into a local AV dealership for a reality check.
Suggesting that consumers purchase five full-range speakers to avoid the bass management issues produced by their processor doesn't seem like the smartest business strategy to me...Maybe Rotel is expanding their product line to include full range speakers
So far all that they have publically said is that its their oppinion that their bass management follows the standards imposed by DVD-A and SACD ie 5 large speakersWhere did Rotel see that the "standards imposed by DVD-A and SACD" demand 5 large speakers? The SACD/DVD-A mixing engineer whom Rotel quoted certainly didn't feel that the standards demanded 5 large speakers. Furthermore, it seems like Rotel is missing the big picture here... Even if the SACD/DVD-A formats had been written for five large or full-range speakers, it's still the job of the preamplifier/processor to deliver this sound through any reasonable speaker configuration. (By "reasonable," I mean that your system is capable of reproducing bass adequately, even if any one particular speaker is not.)
